BASICtools general questions
Posted: Wed Oct 24, 2012 3:03 pm
> 4. I don't see any way of listing the program once it is in the
> system. I guess once it moves from the input buffer it is converted
> to machine code and is not available on a symbolic level. I assume
> the best thing to do is just work with the text editor image of the
> program and reload it as the program grows. The memory dump looks
> like it will only be useful in tables and ASCII data.
Once the text is loaded, the source is not stored on the ARMexpress.
The next TclTerm will capture your typing be able to save it to a
file. Admittedly the dump @ is not too useful without a memory map,
and that will be addressed. We used the @ to debug the ARMbasic and
left it in, as it will be used by TclTerm to query memory.
BASICtools now has a LIST command when you are entering programs line by line, you can then cut and paste that into a text editor
> 5. Is there anyway to determine how much program room is left and
> any given time? Some type of available memory function?
Currently no, but this is a function we have on the BASIC-8 products,
so we will add this in some future release.
The latest compiler reports space used and available for BASIC programs
