A few days ago I upgraded MakeItC. How to see the C-code in the ASM listing? All
that is there is the assembly listing making it difficult to locate the assembly
code for the C-code line. Should -fverbose be used? Where should that option be
placed? I tried it under options/compiler options, no help. The former MakeItC
showed the C-code in ASM Listing.
Thanks
seeing source files included in ASM listing
Re: seeing source files included in ASM listing
I don't have an answer for you, but it's something that has worked in the past,
though on occasion it would not, we never figured out why.
You might check the gnuarm or lpc2000 forums.
You need to use the -g compiler option to see interleaved asm and C code in the
.lst file,
Chris Burrows
Astrobe v4.2: Oberon for Cortex-M3
http://www.astrobe.com
.lst file,
Chris Burrows
