timing instructions
timing instructions
A quick way to check the timing of a set of instructions-
#include <SPI.bas>
dim a(100) as string
x=1000 ' for more resolution make this 1000000
while x
x=x-1
' insert test code here
SPIIN(0,1,2,3,0,0,"",10,a)
--------------- results ----------------------
Welcome back to ARMbasic Kernel[7.05] Copyright 2007,
Coridium Corp.
Programming Flash 2103...*+*+
... 2.45K code 0.25K data programmed
Executing...
... Finished in 275 ms
So for this SPIIN of 10 bytes takes 275 usec or average of 27usec per
byte
CAUTION, if you include print statements you will be waiting for th
19.2Kbaud operation
