interrupts in C
interrupts in C
> Does anyone know if there's a way to do interrupts in C? I'd like to
> set a timer and have a routine called when it pops. I don't need
> HWPWM or UART services, so there are some timers available.
Check the init_coridium() routine in coridium.c
While it is #ifdef'd out when not targeting the ARMweb, that same code
will work for the ARMexpress, with slight modification. The timers
are a little different on the 2103/2106
Here is the code that initialized timer interrupt for 2103/2106
void INT_T1MR0(void) { // timer interrupt
callYourCodeHere()
T1_IR = 1; // clear interrupt
VICVectAddr = 0; // Acknowledge Interrupt
void f_intTIMER (int elapsedTime) {
disableIRQ();
// Setup PWM Compare-Match Interrupt
T1_TC = 0;
T1_PC = 0;
T1_MR0 = elapsedTime - 1; //user match in ms, count from 0
T1_MCR = 3; // Interrupt and Reset on MR0
T1_PR = PCLK/1000-1; //1 ms prescaler
T1_TCR = 1; // TIMER1 timer Enable, turn on ethernet irq
VICVectAddr5 = (unsigned long)INT_T1MR0;
VICVectCntl5 |= 0x25; // use it for TIMER1 Interrupt:
VICIntEnable |= 0x20; // Enable TIMER1 Interrupt
enableIRQ();
Your interrupt service code should be added in ISR.c
The interrupt settup can go anywhere else (this is due to the
optimizations on ISR are minimal, and often those optimizations break
interrupt code)
