ISR Fault
Posted: Sat May 11, 2013 6:16 pm
by danlee58
My SuperPro is running my C program, until I plug in my external connector. The external connector supplies the power and Input signals, as well as the output loads. One of the Input signals is an interrupt.
I get an error message on TCLTerm. ISR Fault oxFFFFFFF1 SCB0x00002000. It appears that there is a proplem with the Interrupt handling.
What does that error message indicate?
Re: ISR Fault
Posted: Sat May 11, 2013 9:44 pm
That is the default interrupt routine, so your interrupt happened, it just went to the default code.
Which means your code never redirected the interrupt to your code.
