My SuperPro is running my C program, until I plug in my external connector. The external connector supplies the power and Input signals, as well as the output loads. One of the Input signals is an interrupt.
I get an error message on TCLTerm. ISR Fault oxFFFFFFF1 SCB0x00002000. It appears that there is a proplem with the Interrupt handling.
What does that error message indicate?
ISR Fault
Re: ISR Fault
That is the default interrupt routine, so your interrupt happened, it just went to the default code.
Which means your code never redirected the interrupt to your code.
