> I'm new to Coridium and ARM processor. I see you have C software support but I wonder how the C handle interrupt service routine? Any example with interrupt handle would be appreciate.
In the Cortex parts interrupts are very easy to handle.
Most peripherals have a dedicated interrupt vector, and there is "place-holder" code for each. That code is defined as a "weak" link for the linker. What that means is if you define the same routine in your code it takes precedence over the weakly defined version.
A good example of that is for the UARTs, where the code supports both TX and RX interrupts.
Look at the startup.S IRQ_cortex.c and .h, uart.c and uart.h in the CMSIS\include directory
