Variables window
Posted: Sun Jul 13, 2014 5:08 am
eval of the '812, ARMBasic 9.33b, [kernel 8.33 I do believe] - variables window from the BT tools tab
playing around with DIM blah(nn) as STRING & DIM stuff(nn) as BYTE
WHEN I did add the 'as BYTE' and played with it -- I got the corruption that I highlighted <---issue #1
initially - I had the 'as BYTE' after the 'as STRING' but it still showed up on the top of the display -like the picture;; LATER I moved the 'as BYTE' as the first DIM'd statement and it didn't change the view in the window - okay - I can live with it
issue#2 --> the 'as BYTE' array doesn't show all my data UNLESS I declare it as at least 64 (if I remember correctly)
I know that a (15) or (16) will not show but more than the two groups of hex characters
I've tried to arrange the picture to show the program working, no errors running or loading, as well as the bulk of the program
in the bigger program that I loaded and ran - I was attempting to clear the string memory but I used the "$" instead of 'as STRING'
is that an issue?? ALSO I did not assign any data to the string - I assumed it would zero it like a common variable. ??good assumpt??
PS. will the variables window be available in the Multi-Core Basic Tools??
