BasicTools - variables address tool
Posted: Wed Aug 13, 2014 3:01 pm
WoW - I really like having the variables and the variable addresses in a alphabetized order !
WoW- WoW on having the variables addresses now !! to a nuts an volts guy - that is icing on the cake !! THANKS
now for some work - I get this when I "x" out of the variables address popup window:(this is the message details)
bad window path name ".symbols"
while executing
"winfo geometry .symbols"
invoked from within
"set symbolWgeom [winfo geometry .symbols]"
(command bound to event)
I have 25 variables - integer, byte, and string
I HAD to click on the error message popup <Okay> button 12 times to get it to go away
Re: BasicTools - variables address tool
Posted: Wed Aug 13, 2014 3:26 pm
More info -- Prostart board
ran the "BLINKY" program - only one integer variable - but still had the 12 <OK> to exit
would the kernel have anything to do with it??????
