FYI -FWIW - trigraph error
Posted: Tue Aug 26, 2014 3:37 am
I found the error by the line number :: I had " Voltage = AD(??) -- hadn't decided on the channel - corrected it
'''--a single ? doesn't cause any concern/errors !!! - is that a problem??
the internet indicates it is part of the C preprocessor [from way back when] -SO you are catching R foibles !!!
Analyzing C:/Coridium/Basic.mbd2/Examples/Bchip_event_logger07.bas
C:/Coridium/Basic.mbd2/Examples/Bchip_event_logger07.bas:168:14: warning: trigraph ??) ignored, use -trigraphs to enable
Programming Flash 1114...
Having Fun , Still !!??
A trigraph is a throwback to the old days when people didn't have keyboards with lots of symbols.
eg.
??= is #
??( is [
??/ is \
??) is ]
and so on.
Re: FYI -FWIW - trigraph error
Posted: Tue Aug 26, 2014 4:48 am
Well we don't go randomly typing junk into the compiler to see what comes out, as the old saying garbage in garbage out
But it is something the compiler should flag, and we'll look into why it doesn't
Posted: Tue Aug 26, 2014 2:27 pm
I got to thinking about this, and you are correct - garbage in garbage out.
the thinking part: you could check for a non-numeric, as each chip has a different amount of AD channels
(so it would be sort of hard to do a bounds check-though I'm sure 32 for AD channels would be enough)
IO(x) would be more difficult - there are at least four Ports -- so now you are upto 128 in a bounds check
AND now - your SELECT CASE indicates that it will treat an ASCII as a number - so a non-numeric check
could be a conditional situation.
testing for Junk - how far do you go ??!!!!
Just thinking out load.........
Posted: Tue Aug 26, 2014 3:10 pm
The compiler is not going to check for out of bounds operations, yes some do (I believe Algol did), but C does not. Part of the reason we won't is the same compiler is run on the ARM for handling <?BASIC in web pages, and there we are quite memory constrained and the alternative of using more #ifdef's is just too hard to handle.
In cases where the (index) is a variable that can't be done until runtime, and to check that would hurt performance.
Posted: Tue Aug 26, 2014 3:35 pm
? is a special character that BASICtools uses to get firmware vectors from the ARM PCB and then send them to the ARMbasic compiler.
The handling of it by the compiler was not very rigorous and that has been fixed. Posted here--
http://www.coridiumcorp.com/forum/viewt ... ?f=9&t=637
