incomplete error message ?
Running a program on the '812 eval chip snippet--
SetTime:
r_index = 0
gosub pretty_string(secs$)
done:
print "time is set"
call RTC_read_time
return
I renamed the RTC_read_time to RTC_display_time
and didn't catch all the places that I referred to it.
When I tried to Reload File I got the following error message -- line number appears to be missing on a 'CALL' type of subroutine??
Analyzing C:/Coridium/Basic/Projects/812_hvac_relay_brd01.bas
Programming Flash 0812...
ARMbasic[9.34g] on the PC Copyright 2014, Coridium Corp.
... ( 2.41K code + 0.41K const)/4K 0.36/1K data programmed
-ERROR Undefined Label RTC_READ_TIME
it was also in this Select Case !!
case 1 to 9
' case 1 'display time
if choice = 1 then call RTC_read_time
' case 2 'set time
if choice = 2
I saved the /TEMP folder files if you want them .
Thanks, Gary
Re: incomplete error message ?
If you are still trying to CALL RTC_read_time which doesn't exist, you're going to get error messages.
Errors can cascade and you end up with errors on errors and at that point not much point in going any further until the first errors are fixed.
Sounds like a case of GIGO, garbage in garbage out
after further testing ; an undefined gosub/funcion/call routine will generate an "undefined label" without a line number.
IF there are any issues in the calling or passing of variables - you will get a line number
different kinds of garbage !! - NOW I know.
This is a feature. When most errors occur, the compiler is handling a certain line. But for labels that are not declared it doesn't know that until the end of the file and the compiler does not keep a list of line numbers for labels.
