incomplete error message ?
Posted: Tue Nov 25, 2014 9:12 pm
Running a program on the '812 eval chip snippet--
SetTime:
r_index = 0
gosub pretty_string(secs$)
done:
print "time is set"
call RTC_read_time
return
I renamed the RTC_read_time to RTC_display_time
and didn't catch all the places that I referred to it.
When I tried to Reload File I got the following error message -- line number appears to be missing on a 'CALL' type of subroutine??
Analyzing C:/Coridium/Basic/Projects/812_hvac_relay_brd01.bas
Programming Flash 0812...
ARMbasic[9.34g] on the PC Copyright 2014, Coridium Corp.
... ( 2.41K code + 0.41K const)/4K 0.36/1K data programmed
-ERROR Undefined Label RTC_READ_TIME
it was also in this Select Case !!
case 1 to 9
' case 1 'display time
if choice = 1 then call RTC_read_time
' case 2 'set time
if choice = 2
I saved the /TEMP folder files if you want them .
Thanks, Gary
SetTime:
r_index = 0
done:
print "time is set"
call RTC_read_time
return
case 1 to 9
' case 2 'set time
if choice = 2
Thanks, Gary
