archpro stop action
Posted: Sat Dec 06, 2014 5:39 pm
to stop the archpro.med type of s/w - you are prompted to pusht the reset switch.
this erases all of the variables information !!!
putting in a STOP command (in the program) won't allow me to look at the Tools/Variables windows
from the STOP command help page"
When the STOP is executed the BASIC program halts execution, but allows BASICtools to dump variable values.
olzeke51 - off to work
PS - I'll try the END command (when I get home) for giggles. the mbed might have a different interface with the chip and such.
Re: archpro stop action
Posted: Sun Dec 07, 2014 2:14 pm
mbed and ArchPRO do no give us access to the reset which is needed for executing a STOP button, so we have to prompt the user to push the button.
Variable dumps should work in STOP, but I believe there is an issue with the INSTALL firmware menu item that erases the Variable dump command.
Posted: Sun Dec 07, 2014 2:25 pm
by AMDlloydsp
Well, Gary... The button issue (by itself) sounds like it's amenable to being solved by your prior suggestion for my reset issue.
LLoyd
