to stop the archpro.med type of s/w - you are prompted to pusht the reset switch.
this erases all of the variables information !!!
putting in a STOP command (in the program) won't allow me to look at the Tools/Variables windows
from the STOP command help page"
When the STOP is executed the BASIC program halts execution, but allows BASICtools to dump variable values.
olzeke51 - off to work
PS - I'll try the END command (when I get home) for giggles. the mbed might have a different interface with the chip and such.
archpro stop action
Re: archpro stop action
mbed and ArchPRO do no give us access to the reset which is needed for executing a STOP button, so we have to prompt the user to push the button.
Variable dumps should work in STOP, but I believe there is an issue with the INSTALL firmware menu item that erases the Variable dump command.
Well, Gary... The button issue (by itself) sounds like it's amenable to being solved by your prior suggestion for my reset issue.
LLoyd
LLoyd
