String expressions
Posted: Thu Apr 02, 2015 11:24 pm
>from help line
Armbasic[9.34h]
Welcome to ARMbasic Kernel[7.43] Copyright 2008, Coridium Corp.
for the ARMmite
Programming Flash 2103...
MyString = "My Integer is " & Str(MyInteger) & "mV"
-ERROR C:/Users/Richard/Documents/Coridium/TestSTR.bas: 9: expected comparison operator, found end of line
-ERROR C:/Users/Richard/Documents/Coridium/TestSTR.bas: 9: Expected Operand, found "mV"
-ERROR C:/Users/Richard/Documents/Coridium/TestSTR.bas: 9: expected expression, found & "mV"
-First ERROR at line :9
_______________________________________________________________________________
If you remove the '& "mV' from the concatenation the error disappears and the test program runs correctly
Am I doing something stupid ?
Re: String expressions
Posted: Thu Apr 02, 2015 11:34 pm
Astr = "something" & str(x) & "else"
Well you know, you're just doing a case we did not expect in the parser. The use of strings is not consistent across BASICs and is a special case, yes this is a "feature", one that we may look at some time if we are ever mucking with strings in the compiler again (but don't hold your breath). Why? Because there are a bunch of different ways to do the same thing, that the compiler does like
Astr = "something" & x & "else"       ' in this case the STR(x) is implied
Astr = "something" + str(x)
Astr = "Astr & "else"                 ' just make it 2 statements
Astr = sprintf("something %d else",x)
While these above are all simple expressions. Strings are handled with one string accumulator, so some string expressions would be too complex to handle, as to parse them we would have to "push" the string onto the stack, and we are not going there.
