Hello Bruce,
In attempting to create an 'AT.bas' file that contains the AT commands
for the esp8266, I was considering using a PARAMARRAY as it was noted
as being 'global'. A) I found that the elements can only be accessed
within the SUB/FUNcTION . I tried to 'DIM PARAMARRAY P' --error, tried
to PRINT P(3) - Undefined Label P
B) each time a Paramarray is named (even with the same name; different SUB)
it takes up 64 bytes of RAM for each Paramarray!! - consuming precious RAM
[It will re-use that same memory if the SUB is called a second time]
This conflicts with your statement in the on-line help for 'paramarray':
"There is only one PARAMARRAY allocated for a BASIC program, so a SUB/FUNCTION
using a PARAMARRAY should not call another SUB/FUNCTION with a PARAMARRAY."
my program:
DIM Static(15)
dim i
dim paramptr
dim paramptr1
SUB Test (paramarray P)
for i = 0 to 14
P(i) = 300 + i
next i
print "sub"
print P(5), P(15)
paramptr = ADDRESSOF P
print paramptr
print
ENDSUB
SUB Test1 (paramarray P)
for i = 6 to 14
P(i) = i
Static(i) = P(i)
Static(15) = p(15)
next i
print "sub1"
print P(5), P(15)
paramptr1 = ADDRESSOF P
print
ENDSUB
Main:
gosub Test(5,4,3,2,1)
gosub Test1(5,4,3,2,1,99,98,97,96,95)
print "main"
print Static(2),Static(7),Static(15)
gosub Test(9,8,7,6)
print paramptr
print paramptr1
END
Paramarray redux
Re: Paramarray redux
Originally the code was going to use a globally defined space for paramarray. That definition is in the firmware and is not directly accessible from BASIC. It is still used by calls to MAIL functions for the Ethernet enabled devices.
But it turned out to be simpler to allocate it like other arrays. So it is unique to each definition, and space for 15 items and 1 count is allocated each time. So I have removed that statement from the help files.
