>from the helpline
>Hi i need to convert an int into a string but cant use \'itoa\' as it does not
seam to be included in the Coridium c lib.
Download the full Yagarto Tool Setup.
http://www.yagarto.de/
Poke around and you'll find the source for itoa or other standard C libraries.
Or you could use sprintf
expanding the C library
Re: expanding the C library
> >from the helpline
not seam to be included in the Coridium c lib.
In addition to Bruce's recommendation the source code for a version of itoa is
included in the "C Bible" i.e. "The C Programming Language" by Brian W.
Kernighan and Dennis M. Ritchie. Every C programmer should have a copy.
Chris Burrows
CFB Software
Astrobe v3.2: LPC2xxx Oberon-07 Development System
http://www.astrobe.com
Chris Burrows
CFB Software
sprintf was perfect
thank you
thank you
