parity in bit banged serial
Questions on UARTs, and serial communication
When using the bit banged UART, is there a way to change settings besides the
baud rate? For instance, 7/8 bit, or a parity bit?
Re: parity in bit banged serial
Yes, the source for BASIC is in the /program files (x86)/coridium/BASIClib
directory, SERIAL.bas
Thanks Bruce, I had no idea that was there.
I dont actually see any definitions, or variables to directly set the number of
bits, or the parity bit. I assume these are modifications I would simply have
to make to the code manually. I am fine with that, I just wanted to verify that
I wasnt missing something.
When those were written it was for just 8 bit, 1 stop bit. But you can change
the limits in RXD and TXD to do 7 bits. Actually with parity, you'd have to
compute that and place that in bit 8 and the limits would be the same.
I am sorry, I am not very familiar with BASIC. I assume the limits are
controlled by the final 'while' loop in the command, in RXD for instance the
while loop is 'while i < $100'. I cannot figure out what '$100' is, but I am
guessing it would control the number of bits to receive.
Rather than
for i=0 to 8
ch and (1 << i)
next i
the code is
i=1
while i < &H100 ' hex bit 8 &H VB syntax, $ is PBASIC, both are OK
ch and i
i = i << 1
I have been looking through the code, and I cant seem to find anything which
helps prevent framing errors in the event that packets come in very fast and
only 1 stop bit is used.
Am I missing something, or is it assumed that the data packets will arrive
sufficiently slow?
If you're worried about something like that, you should be using one of the
hardware UARTs, the SuperPRO has 5
