Random numbers
Random numbers
>I need a random number generator, rnd() to include in a Basic type program to
run on a SuperProPlus. I see that the rnd() function has been moved to the
pbasic.lib library. Where can I obtain a copy of that peogram or library?
Yes we did take random out of the firmware, to make room for floating point
(especially in the BASICchip where we're down to 50 bytes in the allocated 12K).
And we need to publish that routine in BASIC. There may be better ones out
there especially with floating point, but what was in there was-
FUNCTION random(seed)
seed *= 279470273
return seed MOD &HFFFFFFFB
END FUNCTION
My question is, I've been writing code for 35 years and other than classroom
exercises I've never needed a random number. What do people use it for?
Re: Random numbers
Most games need some kind of random generator, TCP incorporates a random backoff
time delay between a failed packet and resend request (to keep the sender and
receiver from predictable collisions in resend sequences), Quote of the Day
daemons often randomize rather than return quotes in a predictable order...
Basically anywhere it's desirable to breakup simple, mundane, easy-to-recognize
patterns, by replacing them with complex, hard-to-recognize ones, you'll find
random number generators. :-)
-MM
Re: Random numbers
As I don't write games often or do network back off algorithms, I have yet to
ever need a random number.
The version I published is not working, (mod with negative number is returning a
simple sequence). So I'm looking for input from the community.
A simple thing I might suggest is just read the TIMER when user input is
received. It counts in microseconds, and if you use the low order bits, I doubt
anyone has good enough rhythm to be able to generate non-random values.
Re: Random numbers
There are a couple simple ones
herehttp://en.wikipedia.org/wiki/Random_number_generation and they suggest
seeding with the RTC value.
Googling (Design of pseudo Random number generators) will get you more.
Re: Random numbers
// This works surprizingly well. ... I am shocked at how
// good the distribution is. Take a peek at the following image
// http://gyazo.com/83546e60d2dfeaa97b0ddc41f4edc269.png
// I got the code from this site and ported it to ARMbasic.
// http://www.bobwheeler.com/statistics/Pa ... iaPost.txt
/* Adapted to 31bit space since AB uses singed ints and shifting
signed negatives retains the sign vs. treating them like unsigned... */
/* Global static variables: */
dim _z, _w as integer // used by mwc random number generator
function znew
_z=36969*(_z and $ffff)+(_z>>16 and $ffff)
return $7fffffff and _z<<16
endfunction
function wnew
_w=18000*(_w and $ffff)+(_w>>16 and $ffff)
return _w and $ffff
endfunction
function mwc
return (znew+wnew)
endfunction
function rand as single
dim u as integer
// Produces a random sample from the open interval (0, 1).
// The method will not return either end point.
// 0 <= u < 2^31
u = mwc
// The magic number below is 1/(2^31 + 2).
// The result is strictly between 0 and 1, exclusive of either.
return (u + 1.0) * 4.656612868740580000E-10
endfunction
sub init_globals
' _z = 362436069 ' default static seed
_z = timer and $7fff0000 '<- use a static seed if you want repeatability...
_w = 521288629
endsub
dim x as integer
init_globals
// this loop creates 100000 pairs of random numbers
// I did this to copy and paste into excel and then do a graph
// to demonstrate the distribution
// a image of the graph is shown here:
for x = 1 to 100000
Print rand, rand
next x
end
Re: Random numbers
Also, the source and a spreadsheet were uploaded to the files section in June:
Enjoy.
-t
IEEE 754 Random Function.zip
(929.99 KiB) Downloaded 1348 times
Re: Random numbers
In the early 90's we used to use the timer as the seed in Quick Basic with the
following command.
RANDOMIZE TIMER
The timer as a seed value is fairly common as I think someone else recommended
the timer.
