I need insulating mounting hardware to mount my Super Pro board in an aluminum enclosure.
What size screws are needed to mount the Super Pro?
Are they avaiable in insulating material?
Super Pro Mounting Hardware
Re: Super Pro Mounting Hardware
I found the hardware that I need at www.sparkfun.com.
The screw holes are 0.125" and are not connected to anything on the board, so #4 in SAE or M3 in metric should be the correct bolt size.
For those of you who haven't discovered them, McMaster stocks virtually every nut, bolt, standoff and most any other hardware you will ever need.
