Here's a few you might want to be aware of
1) On the main webpage there is a section for students etc and one for engineers etc - in both sections the featured board was the PRO Start Board - but the second section says the speed is "3 to 6 times faster" - I think you meant to put the 100 Mhz Pro-Plus Board there.
2) In the specs for the basic chip ( http://www.coridium.us/prod-specs1.html) - it lists that it is .06 inches wide. Quite an accomplishment
3) In the example in the docs for the STR function is this code
DIM bstring (10) AS STRING
a = 8421
b = STR(a)
PRINT a, b ' will display 8421 8421Should be
a = 8421
bstring = STR(a)
PRINT a, bstring
