The Help files haven't caught up yet and we are still testing a couple new compiler features. We have followed the VB syntax
PARAMARRAY is now supported for calling SUB and FUNCTION
SUB x (PARAMARRAY z)
' you can use z(0) thru z(14) as values here -- z(15) contains the max index of the PARAMARRAY -- always limited to integers and 15 values
ENDSUB
x(1,2,3) 'ok
x(5,6,7,8,9,10) ' also ok
BYREF passing of INTEGER and SINGLE arrays to SUB and FUNCTION
FUNCTION f(z() AS SINGLE) AS SINGLE
return z(0)+z(1)
ENDFUNCTION
DIM zz(10) AS SINGLE
zz(0)=1.111
zz(1)=2.222
print f(zz)
Compiler updates
Compiler updates
- Attachments
- ARMbasic.exe
- ARMbasic 8.23d compiler
- (121.68 KiB) Downloaded 1302 times
Re: Compiler updates
The compiler has been updated to allow the deprecated declaration of string$ in function and sub parameters. Much earlier versions of the compiler allowed this, but with the conversion to floating point that changed.
So our regression tests add tests for that and the compiler once again handles
function something(astring$(10))
This version also handles sub and functions with no parameters using the form
sub somethingelse()
The compiler did not allow () before.
sub somethingelse()
- Attachments
- ARMbasic.exe
- version 8.25f handles deprecated string parameters and no parameter case
- (122.18 KiB) Downloaded 1287 times
This update covers extensions for LPC4xxx series parts which are being used in some custom designs. If demand drives it they may also become part of the product line.
In addition we found a bug in certain instances of the compiled code for interrupts for the Cortex parts LPC1114, LPC1751 and LPC1756. This has been corrected in this version.
- Attachments
- ARMbasic.exe
- (117.55 KiB) Downloaded 1234 times
This version of the compiler improves the compile time evaluation of most constants. Before if the constant was too complex it could get evaluated at run time.
This version also improves the handling of floating point code that also includes integer constants. This improves the performance of the simple test case by 30%. The test case is below
For the SuperPRO that gets floating point performance close to 1 MFLOP in BASIC
DIM x as single
x=1000000
while x>0
x=x-1
- Attachments
- ARMbasic.exe
- version 8.27d of the ARM BASIC compiler
- (119.73 KiB) Downloaded 1292 times
This version of the compiler fixes an introduced bug for the statement
DIR(expression) = expression
We have added tests for that and most other pin functions into the test suite.
We were getting short of opcodes for a while, and that meant some of the obsolete DATA statements shared an index with the new WAITMICRO, and in trying to support both depending on firmware version WAITMICRO got broken.
So for now we don't support the obsolete DATA statements, probably won't again. Version 9.33b fixes WAITMICRO
BASICtools and the ARMbasic compiler have been updated to expand the variable dump debug tools. The code dump now shows all subroutines, and there is a variable address page that can be used to figure out what BYREF pointers are pointing at.
Too big to post here, so best is to download www.coridium.us/files/setupBASIC.exe
It has updated ARMbasic.exe, BASICtools.exe, TclTerm.tcl and numerous updates to the help file.
Since the last some more optimizations have been added for single arrays. Those are in this version 9.34e of the compiler.
This version tightens up handling of ? which is a special character used by BASICtools to communicate with the ARM PCB and the ARMbasic compiler.
version 9.34f
version 9.34f
wow - you got rid of 6k bytes over a "?" !!!
