Back to Basics
TodWulff
Back to Basics
Post by TodWulff »
I was struggling a bit with my old gray matter not being as nimble & fluid as it used to be (sadly).
This realization predicated that I go find and reacquire some old attrited knowledge, in the form of reference material.
I came across some good references (a.k.a. 'gouge' for some of us military types).
I am writing to make it easy for folks to get their hands on them, should it be of potential value to someone else.
They are attached herein.
Sources:
https://www.allaboutcircuits.com/assets ... erence.pdf
https://www.tek.com/blog/tutorial-digit ... n-r-2r-dac
http://wbrc.in/ham/getting-started-in-e ... ms-iii.pdf (too large to attach)
https://www.zpag.net/Electroniques/Kit/ ... tebook.pdf (too large to attach)
Here is what appears to be a robust piece: The Art of Electronics (too large to attach)
http://www.n5dux.com/ham/files/pdf/ (<-- A nice library of reference works with an acute slant toward the HAM realm)
I'll work to update this post as I come across more. Until then, take care.
Resistor Ladder DAC.pdf
(306.61 KiB) Downloaded 1937 times
ElectronicsReference.pdf
(840.81 KiB) Downloaded 1652 times
TodWulff
Re: Back to Basics
Post by TodWulff »
The R-2R Resistor Ladder DAC works well:
