ARMStamp RXD issue
Questions on UARTs, and serial communication
ARMStamp RXD issue
First off - some of this is unorthodox procedure !!
Attempting to create a Serial Comm link with the ARMstamp - I tested the ability to TXD first. -- Works,but
did notice some "funnies" - a different Forum post.
Did not connect the RXD line - (so it is floating?)- but later on did a RXD test and got the "garbage"
as can be seen in the "Debug Variable portion of the picture" - code snippet/function was copied from
one of your forum links re: serial. called 'getline' - [OEM current testing via SPI devices]
connected RXD to the Coridium Dongle and I get nothing - not even 'garbage'/CR/LF- from TclTerm which is
connected to the Dongle
tested on ARMstamp Production and Beta unit - both fail ::: SuperPro works fine on BAUD(0) & TclTerm & Dongle
Could you verify RXD works at 19200 baud on the ARMStamp ???
Olzeke
P.S. a picture is worth ......
Re: ARMStamp RXD issue
RXD1 and TXD1 use to be handled by a dedicated firmware routine that no longer exists, hence the error
Yes the Help file should be fixed (a never ending process, but thanks)
On the ARMstamp, the serial channel 0 is routed through the USB which is quite different than the serial hardware. Baudrates don't matter there as the Windows USB serrial driver ignores them. TXfree also always shows totally free, as buffers are passed to the USB code in the ARM
If you have old code using RXD1 and TXD1, a good workaround would be
#define RXD1 RXD(1)
#define TXD1 TXD(1)
If any RXD(x) input is floated, you get whatever. If you want it to show idle, you need a pullup.
TXD(1) working for me (ARMstamp -> USB dongle)
baud(1)=19200
for i=1 to 20
txd(1)=&H40 + i
next
The TXD situation was workable.
the main issue was the RXD(1)- actual data getting in.
it is interesting that the floating input , would actually capture the TXD data - for a short while !!
[see the COMMAND data display - that was the RXD(1) data whhile the input was floating !!]
can you test the RXD(1) function ????
Thanks - gz
Any floating input can generate any kind of data -- not very surprising.
And this working for me
' this assumes a connection between RXD(1), TXD(1) and some other serial device using TclTerm, TeraTerm...
' tested with a USB dongle and ARMstamp
baud(1)=19200
for i=1 to 20
txd(1)=&H40 + i
next
ch= rxd(1)
while ch<>"X"
  ch = rxd(1)
  if ch>0 then print chr(ch);
PS you should hook up GND as well as TXD and RXD lines
Hello Y'all,
I have egg on most of my face. You need to know your tools & apps!!
Basicchip was VERY patient and helpful. He put in 2+ hours one afternoon,
and then 3 more late night/early morning posts (off channel). Drug out
his hardware and did testing, even created some little routines -
[might be a blog item !?!?!?].
The main issue was receiving data from the TclTerm.exe (Tterm) program;
that comes with the Coridium Basic install - its in the root folder.
Turns out that with Windows being multi-windowing with many open apps,
some of them get shifted around so you can see different app-statuses.
This was my case - Tterm was shifted down so that I only saw the
terminal(or received data) portion. When you select Tterm to have the
focus of the keyboard and click on that terminal/data portion (to select
Tterm as the focus)- that is where the cursor ends up blinking.
As an old-timer - a 'terminal' device with a blinking cursor means that
it is waiting for you to enter data....AND that is what I did -but had
no results. I even loaded up a 2nd computer with Tterm - same results!
Nada, zero, nothing, blank screen....
Turns out - Tterm has a single-line "ENTER" window down at the bottom!!
and that is where the blinking cursor needs to be to 'Enter keyboard data'!!
Note: if you 'cursor/mouse' there before you switch to another app; then if
you click the Tterm title bar to select it - your 'ENTER' window will still
have the focus and you can start keyboarding. This was an additional 2 hours
of my time today.....
Know your tools - Olzeke
BAUD_test.bas
(744 Bytes) Downloaded 1901 times
******* 11u37 serial info, and two 'funnies' discovered ****
TXD(0) will output to the USB connector
TXD(1) outputs to the onboard USART-SOUT pin
RXD(1) inputs received data from SIN pin
BAUD(0) OR BAUD(1) will program the USART baud rate !!!
see BAUD_test.bas
TXFREE(0) will report the status of the USART buffer of TXD(1)
TXFREE(1) [or any other number] reports a -1
Both those expected, as while we have UART0, and the debug port which has always been RXD(0) and TXD(0) on all other parts.
So what to do???
well we intentionally send TXD(1)/RXD(1) to UART0
So I guess we'll look at BAUD(0) affecting UART, it should not, but BAUD is actually ignored on USB driver, so it really never would get used
But we will look at TXFREE for UART, as it also has no meaning for on chip USB serial devices
My main goal was to document the work-arounds/ awareness. If/when the
kernel needs/gets updated - it could be incorporated at that time.
But to do it specifically for those two minor situations - might not be a good ROI.
Thanks for the consideration, though.
Gary
UART0 is not a BASIC keyword so .... kind of a grey area - my 2 cents - gz
TXFREE works for me. EDIT -- on a newer firmware version.
Not sure it is worth addressing BAUD(0)/BAUD(1) interaction on Stamp, as BAUD(0) would really never get used there. Here is my test code--
baud(1)=115200
free0i = txfree(0)
free1i = txfree(1)
TXD(0) = 0x41
TXD(0) = 0x42
TXD(0) = 0x43
TXD(0) = 0x44
TXD(0) = 10
free0 = txfree(0)
TXD(1) = 0x45
TXD(1) = 0x46
TXD(1) = 0x47
TXD(1) = 0x48
TXD(1) = 10
free1 = txfree(1)
printf("free %d %d %d",free0i,free1i,txfree(2))
printf("free %d %d %d",free0,free1,txfree(2))
In the current release of firmware 8.40b, txfree is broken on the LPC11U37, the ARMstamp
If you really need this function, contact me and I will send a corrected firmware.
