I don't know how helpful it will be to others, but just in case, here ya go. I hope someone benefits from it.
' Construct Timing Test Tool
' used to ease the determination of timing of ARMbasic code constructs on Coridium Targets
' ' Revision History
'v 1.01 02Oct18 Maintenance/Bug Fix Update
' • typos fixed, comments added, defaults manipulated a bit, refactored again, etc.
' • Had a pretty big issue with how I was handling resolution limiting - resolved by
' • scrapping the whole rounding approach and resorted to firmware sprintf code use. :)
'v 1.00 02Oct18 Initial Release
' • ample comments/diatribe and code are descriptive of initial implementation
#define _Construct_Timing_Tester_Version "1.01"
// note the '~~ | '~ pairs you see littered below are for folding purposes
// in my editor. They can be ignored or removed as you deem fit. I just
// like to fold up stuffs that I am not touching to declutter the editor's
// UI - makeing things more navigable/intuitive (and me happy... ;).
// Also note that I make use of // in addition to ' to impute comments
// considering my ARMbasic language definition in NPP allows for toggling single line comments,
// which I use to quickly enable/disable code blocks. By making use of // comments,
// same isn't accidently uncommented when I select a larger code block for uncommenting...
'~~ // #DEFS/#INCLUDES FOR THE TEST CONSTRUCTS HERE <----== IF NEEDED, HERE IS WHERE TO DO IT
// do any #defines/#includes here as needed for the test constructs, or setup thereof
'#define something_used_by_#included libs
'#include "x:\somefolder\somefile.lib"
'~~ // testing constructs initialization (#defs) here - leave these be & redefine below
// ignore the warnings tossed at compile for each redefine. It's OK. ... Really. :)
#define Test_Construct_Name "'NullConstruct'"
#define Test_Construct_Code0 ' null
#define Test_Construct_Code1 ' null
#define Test_Construct_Code2 ' null
#define Test_Construct_Code3 ' null
#define Test_Construct_Code4 ' null
#define Test_Construct_Code5 ' null
#define Test_Construct_Code6 ' null
#define Test_Construct_Code7 ' null
#define Test_Construct_Code8 ' null
#define Test_Construct_Code9 ' null
#define Test_Construct_CodeA ' null
#define Test_Construct_CodeB ' null
#define Test_Construct_CodeC ' null
#define Test_Construct_CodeD ' null
#define Test_Construct_CodeE ' null
#define Test_Construct_CodeF ' null
'~~ // INITIALIZATION/SETUP FOR THE TEST CONSTRUCTS HERE <----== IF NEEDED, HERE IS WHERE TO DO IT
// using the man behind the curtain's trick to instantiate globals from w/in a sub
// USER SHOULD AVOID ACCIDENTAL REUSE OF TEST LOOP VARS (w/ leading _ - i.e. _foo, _bar), else results will be unpredictable
dim i,j,k,m,x as integer
dim n,p,r as single
_do_test_setup:
i=0
j=0
k=5
m=addressof k
n=0.0
p=0.0
r=0.0
'~~ // leave the rest of this code block & _pre_process sub be (used for test)
return
sub _pre_process
print "======================================================================"
print
print "ARMbasic Construct Timing Test Tool v";_Construct_Timing_Tester_Version
print
print "Resetting Timer - BT' ";chr(34);"... Finished in xxx ms";chr(34);" will be violated - ignore it..."
print
timer = 0 // elected to reset the timer given liklihood that user test constructs could run a log time here,
// and having a timer rollover could be counterproductive/error inducing/bad
// a FIXME, maybe? (dealing with a rollover programatically, or checking and tossing an error if likely.?.)
// I dunno. Muh gray matter hurts.
goto _do_test_setup
endsub '~
'~~ // CODE THE TEST CONSTRUCTS HERE <-----== THIS SECTION IS WHERE THE USER TEST CONSTRUCTS ARE INSTANTIATED
// Some samples follow. If you comment everything out, the tool will still work (default null constructs above...).
// yeah entering a construct name can be a small pita, but make sure you edit the Test_Construct_Name to
// be descriptive of the constructs actually coded below it - a small bit of effort will yield goodness.
// In looking at main:'s code, you can see how these #defs are used to 'inject' code into the test framework.
// Up to 16 are provisioned for (Test_Construct_Code0 thru Test_Construct_CodeF).
// More can be easily added, of course (above in #def init, in this section, and in main, below).
// But note that more test constructs yields longer test times, so edit the test parameters, as noted below,
// if things are taking forever during the testing.
// these three #defs are a mirror of the Default #defs - useful to demonstrate the testing loop's overhead removal
' #define Test_Construct_Name "'NullConstruct'"
' #define Test_Construct_Code0 ' null
' #define Test_Construct_Code1 ' null
// the rest of these are samples (actual constructs I used to generate sample device-specific timings in the forum post)
#define Test_Construct_Name "'intvar=timer'"
#define Test_Construct_Code0 j = timer
' #define Test_Construct_Name "'intvar=intvar'"
' #define Test_Construct_Code0 j=k
' #define Test_Construct_Name "'intvar=sglvar'"
' #define Test_Construct_Code0 j=n
' #define Test_Construct_Name "'sglvar=intvar'"
' #define Test_Construct_Code0 n=j
' #define Test_Construct_Name "'sglvar=sglvar'"
' #define Test_Construct_Code0 n=p
' #define Test_Construct_Name "'InterruptToggle'"
' #define Test_Construct_Code0 interrupt(0)
' #define Test_Construct_Code1 interrupt(1)
' #define Test_Construct_Name "'FNLoop'"
' #define Test_Construct_Code0 For x=0 to 0
' #define Test_Construct_Code1 next x
' #define Test_Construct_Name "'DULoop'"
' #define Test_Construct_Code0 do
' #define Test_Construct_Code1 until 1
' #define Test_Construct_Name "'WLLoop'"
' #define Test_Construct_Code0 While 0
' #define Test_Construct_Code1 loop
' #define Test_Construct_Name "'IntVarPeek'"
' #define Test_Construct_Code0 i=*00000000
' #define Test_Construct_Name "'IntVarPoke'"
' #define Test_Construct_Code0 *m=0
'~~ // POST-PROCESS THE TEST CONSTRUCT PROCESSING HEREIN <----== IF NEEDED, HERE IS WHERE TO DO IT
sub _post_process
endsub '~
'~~ // these are the testing tool configs - edit as needed, making note of comments here
#define _test_density 10000 // the quantity of loop test per iteration
// recommend 10K to 1M to allow settling, unless test construct is dense/lengthy
#define _test_iterations 10 // used to determine how many iterations of _test_density loops are used in
// developing averages - Min 2, suggest 4 to 10, unless test construct is dense
#define _time_resolution 10 // 6-14 digits of resolution - 6 is uS, 9 is nS, 12 is pS - max is 14
// <6 will break code, more then 14 is of no value. 10 is default.
'~~ // test variables - leave these be
#define _du_loop 1
#define _tc_loop 2
dim _looptime(2) as single
dim _start, _fin, _i, _x, _itime, _presolution as integer
dim _times(_test_iterations), _time_sum as single
dim _spf_format(100) as string
sub _get_test_loop_overhead // uses globals - using DU loops for test loops, as they are fastest - shouldn't need to mess with this...
_x=1
do
_i=0
_start = timer
do
// this is an intentionally null loop construct for OH determination purposes...
_i+=1
until _i>=_test_density
_fin = timer
_times(_x) = 1.0*((_fin-_start)/_test_density) // elected not to round the interim values to avoid cumulative errors
print chr(if(_x mod 2 = 0,"+","*")); '~
_x+=1
until _x >= _test_iterations
_time_sum =0.0
_x=2 // omit the first pass, as they are usually not representative of the balance (i dunno why - suspect related to user app startup.?.)
// might need to be a TODO/FIXME.?.
do
_time_sum += _times(_x)
_x+=1
_looptime(_du_loop) = _time_sum/((1.0*_test_iterations)-1) // -1 as first pass omitted - elected not to round the interim values to avoid cumulative errors
print " | ";
endsub
sub _test_code_constructs // uses globals - using DU loops for test loops, as they are fastest - shouldn't need to mess with this...
_x=1
do
_i=0
_start = timer
do
_i+=1
_fin = timer
_x+=1
print
print
_time_sum =0.0
do
_x+=1
_looptime(_tc_loop) = _time_sum/((1.0*_test_iterations)-1) // -1 as first pass omitted - elected not to round the interim values to avoid cumulative errors
endsub
main: // the main test app code - using DU loops for test loops, as they are fastest - shouldn't need to mess with this...
_pre_process
print Test_Construct_Name;" being tested ";
_post_process
' display construct name and time
_spf_format = str(_time_resolution-6) // adjusting for uS base uom
_spf_format = Test_Construct_Name & " %1." & _spf_format & "f uS"
print SPRINTF(_spf_format, _looptime(_tc_loop)-_looptime(_du_loop))
endCode: Select all
Device specific timing test results
'30MHz LPC824 device specific timing samples
'NullConstruct' 0.0000 uS
'intvar=timer' 2.1927 uS
'intvar=intvar' 0.1482 uS
'intvar=sglvar' 1.5704 uS
'sglvar=intvar' 1.9260 uS
'sglvar=sglvar' 0.1482 uS
'InterruptToggle' 1.8622 uS
'FNLoop' 2.5186 uS
'DULoop' 0.2371 uS
'WLLoop' 0.3260 uS
'IntVarPeek' 0.2371 uS
'IntVarPoke' 0.2371 uS
'50MHz LPC1114 stamp device specific timing samples
'NullConstruct' -0.0370 uS
'intvar=timer' 0.4259 uS
'intvar=intvar' 0.0741 uS
'intvar=sglvar' 1.0000 uS
'sglvar=intvar' 1.2963 uS
'sglvar=sglvar' 0.0741 uS
'InterruptToggle' 2.5926 uS
'FNLoop' 1.6852 uS
'DULoop' 0.0926 uS
'WLLoop' 0.0926 uS
'IntVarPeek' 0.0926 uS
'IntVarPoke' 0.1111 uS
'50MHz LPC11U37 device specific timing samples
'intvar=timer' 1.3889 uS
'sglvar=intvar' 1.2778 uS
'InterruptToggle' 1.9385 uS
'FNLoop' 1.7223 uS
'DULoop' 0.0926 uS
'WLLoop' 0.0926 uS
'100MHz 54102:M4 device specific timing samples
'NullConstruct' -0.0033 uS
'intvar=timer' 0.7050 uS
'intvar=intvar' 0.0152 uS
'intvar=sglvar' 0.5430 uS
'sglvar=intvar' 0.4134 uS
'sglvar=sglvar' 0.0152 uS
'InterruptToggle' 0.9319 uS
'FNLoop' 0.4042 uS
'DULoop' 0.0523 uS
'WLLoop' 0.0616 uS
'IntVarPeek' 0.0430 uS
'IntVarPoke' 0.0431 uSI've noted a single instance of 'unexpectedness': one specific code construct on a single device (the sample DULoop construct on a 11U37 stamp). The tool runs, right up to the end and then it hangs during the final print statement. One must 'stop' the device to get the print statement to complete. It is pretty weird. I've ran this on all the devices I have at my fingertips and no other issues are present that I've observed. Given the observed (repeatable/reproducible/reliable) unexpectedness is seen only in a specific context (a single code construct on a single device type), I am leaning towards sumtin pretty obscure being in play here. Maybe it has something to do with the embedded USB stuffs.?. ¯\_(ツ)_/¯ I'll chase it later, given it is reliably repeatable. In the interim, if someone figures it out, please advise. TIA.
EDIT: Murphy reared his head again. As soon as I posted this, a big bug revealed itself to me. I ended up reworking the program, as depicted herein. The issue I was seeing with the 11U37 resolved itself too, so it was probably my bad code that caused the issue. At any rate, the source herein, and depicted results, have been updated.
Regardless, Enjoy.
