Hi all,
I would like to use RXD(x) function to receive datas but I need to configure the
serial line options like data size (7/8bits), parity or not, stop bit size
(1/1.5/2)...
Where can I have the (C) source code of this function ?
Thanks.
UART non-standard parameters
Re: UART non-standard parameters
the serial line options like data size (7/8bits), parity or not, stop bit size
(1/1.5/2)...
Best to allow the Coridium code to initialize the UART, set up interrupts.
Then you can re-program the UART baud/stop/bits setup, refer to the NXP user
manual for that.
(1/1.5/2)...
manual for that.
