>I have been unsuccess to get the Armmite pro to interface with an external ADC
using SPI. How can I control the clock speed/sampling rate using the SPI
commands in Basic? The documentation states the clock speed is set at 300kbps.
However my ADC supports only 100kbps.
You will need to slow down the SPI for the ADC you are using.
The source for the SPI routine is in
/Program Files/Coridium/BASIClib/SPI.bas
The inner loop for SPIOUT is
while i and $ff
OUT(OUTpin)=(i and outByte)
SPIclkACTIVE
SPIclkIDLE
i = i << 1
something like this might work, you will need to experiment-
while i and $ff
SPIclkACTIVE
SPIclkACTIVE
SPIclkACTIVE
SPIclkIDLE
SPIclkIDLE
SPIclkIDLE
i = i << 1
SPI for self clocked AD converters
Re: SPI for self clocked AD converters
Bruce,
If he/she is not using the microsecond timer somewhere else, something like
this may work:
while i and $ff
OUT(OUTpin)=OUT(OUTpin)=
this may work:
while i and $ff
