Period Of A Sinewave?
Re: Period Of A Sinewave?
I think you are confusing your timer and channel nomeclature
P1[18] can be programmed to be Capture input for Timer 1, channel 0. (from the User Manual)
But your code is programming T0_* which is Timer 0
Post by danlee58 »
OK, I thought that it was Capture Register 1, Timer0. I'll correct that and try again.
Another confusing statement in the user manual for the Timer Control Register is:
'0 Counter Enable When one, the Timer Counter and Prescale Counter are enabled for counting. When 1,
the counters are disabled.'
cfbsoftware
Post by cfbsoftware »
danlee58 wrote:When 1, the counters are disabled.'
Doesn't make a lot of sense does it? That should read: "When zero, the counters are disabled."
Chris Burrows
CFB Software
Astrobe v4.4 (Mar 2013): Oberon Development System for the PRO-Plus and Super-PRO
In newer NXP user manuals that line has been corrected (1 = enable, 0 = disable).
I'll check with NXP to see how / when those kinds of errors get updated user manuals.
Post by danlee58 »
OK, now the Interrupt is working. I can go on to check out the other functions.
