ARMWeb Email Services
Re: ARMWeb Email Services
>from help line
Bruce:
Otherwise Verizon internet customers would not be able to use the service.
They use a high number port for outgoing email. I forget which one.
I suppose they don;t want viruses to do mass mailings.
I don;t know if you would support this construct: jdoe@coridium.us:520
where the port is specified with a colon. Not much of a change would be
required on your end, I suppose and it won\'t break anything.
Another product encountered this sort of problem. Their solution is to mail
to the OEM\'s email server (like your company) which forwards. This, in some
respects is an interesting idea because, you could make a product that
emails someone and you don;t have to setup the email server. Some sort of
authentication/wierdness is built into the forwarding. I don;t know what
it is.
More \"plug and play\" if you will.
We'll keep it in mind, but don't plan to do this for now
