Teensy 3.1 (3.0) with LCD 20x4
jepalza
Post by jepalza »
Hello:
First, I feel my bad English, but I am Spanish, and I am using google translate and dictionary
This is my first project in teensy 3.1 (valid in 3.0) to use a 20x4 LCD in 4bits mode. I am using the project of this thread http://www.coridiumcorp.com/forum/viewt ... ?f=8&t=739 with tweaks to adapt to the teensy and to 20x4 (the original is 16x2).
The connection scheme comes from an arduino project, not mine.
In Spanish (In case the automatic translation is not well understood)
Este es mi primer proyecto en teensy 3.1 (valido en 3.0) para emplear un LCD de 20x4 en modo 4bits. Estoy usando el proyecto de este hilo ..... con retoques para adecuar al teensy y a 20x4 (el original es de 16x2).
El esquema de conexión proviene de un proyecto de arduino, no es mio.
#include "MK20DX128.bas" ' teensy 3.1 (3.0)
#define E  OUT(4) ' Operation enable signal. Falling edge triggered.
#define RW OUT(3) ' Read/Write select signal, R/W=1: Read R/W: =0: Write
#define RS OUT(2) ' Register select signal. RS=0: Command, RS=1: Data
#define DB7 OUT(12) ' Four high order bi-directional three state data bus lines.
#define DB6 OUT(11)
#define DB5 OUT(10)
#define DB4 OUT( 9)
SUB WAIT_US(time as integer)
	dim start as integer
	start = TIMER
	while ((TIMER - start) < time)
END SUB
' 4-bit Initialization:
' send a command to the LCD controller
SUB LCD_CMD(D as integer)
	RS = 0 ' RS=LOW : Command
	RW = 0 ' RW=LOW : Write
	' Send upper 4 bits
	DB7 = D and &H80
	DB6 = D and &H40
	DB5 = D and &H20
	DB4 = D and &H10
	E = 1 ' enable pulse width >= 300ns
	E = 0 ' Clock enable: falling edge
	' Send lower 4 bits
	DB7 = D and &H08
	DB6 = D and &H04
	DB5 = D and &H02
	DB4 = D and &H01
END SUB
' write line 0 or line 1 of the LCD display
SUB WRITE_LINE(line_num as integer, linea(20) as string)
	dim i, j as integer
	' LCD 20x4
	if line_num = 3 then i = &Hd4
	if line_num = 2 then i = &H94
	if line_num = 1 then i = &HC0
	if line_num = 0 then i = &H80
	' set the position
	LCD_CMD(i)
	WAIT_US(50)
	RS = 1 ' RS=HIGH : Data
	i = 0
	WHILE (i < 20) and (linea(i) > 0)
		j = linea(i)
		i += 1
		' Send upper 4 bits
		DB7 = j and &H80
		DB6 = j and &H40
		DB5 = j and &H20
		DB4 = j and &H10
		' Send lower 4 bits
		DB7 = j and &H08
		DB6 = j and &H04
		DB5 = j and &H02
		DB4 = j and &H01
		WAIT_US(40) 'wait > 37 us
	LOOP
END SUB
' write a character to where ever the current position is
' NOTE: remember to delay 40 us between characters
SUB LCD_DATA(D as integer)
	' Send upper 4 bits
	DB7 = D and &H80
	DB6 = D and &H40
	DB5 = D and &H20
	DB4 = D and &H10
	' Send lower 4 bits
	DB7 = D and &H08
	DB6 = D and &H04
	DB5 = D and &H02
	DB4 = D and &H01
END SUB
SUB INIT_LCD
	' TEENSY 3.1 pins
	OUTPUT(4) ' E
	OUTPUT(3) ' RW
	OUTPUT(2) ' RS
	OUTPUT(12) ' D7
	OUTPUT(11) ' D6
	OUTPUT(10) ' D5
	OUTPUT( 9) ' D4
	E = 0
	RS = 0
	RW = 0
	wait(50) ' Wait > 40 msec after power is applied
	DB7 = 0 ' put 0x30? (o 0x03?) on the output port
	DB6 = 0
	DB5 = 1
	DB4 = 1
	E = 0   ' one set/clr = 958 ns
	wait(5) ' must wait 5ms, busy flag not available
	E = 1
	E = 0
	WAIT_US(200) ' must wait 160us, busy flag not available
	E = 1
	E = 0
	E = 1
	E = 0
	WAIT_US(200) ' can check busy flag now instead of delay
	LCD_CMD(&H28) ' Function set: 4-bit/2-line
	wait(1) 'wait > 37 us
	'LCD_CMD(&H0F) '0 0 0 0 1 D C B Display ON/OFF control, display on, cursor on and blinking
	LCD_CMD(&H0C) '0 0 0 0 1 D C B Display ON/OFF control, display on, no cursor
	LCD_CMD(&H01)'0 0 0 0 0 0 0 1 Display Clear
	wait(2) 'wait > 1.52 ms
	LCD_CMD(&H06)'0 0 0 0 0 1 D S Entry Mode Set
	LCD_CMD(&H02)'0 0 0 0 0 0 1 0 Return Home
END SUB
MAIN:
	dim c, i, line_num as integer
	dim S(20) as string
	print "Coridium Wireless LCD Example"
	print "   Enter lines to display"
	INIT_LCD
	WRITE_LINE(0,"**CORIDIUM IS COOL**")
	WRITE_LINE(1,"0123456789ABCDEFGHIJ")
	WRITE_LINE(3,"TEENSY 3.1  LCD 20x4")
	line_num = 2
	i = 0
	S = ""
WHILE(1)
	c = RXD(0) ' read characters
	' accumulate the string, lines of length greater than 20 will be split
	if c >= &H20
		S(i) = c
		i += 1
	' if length is 20 or its a new line and length is greater than 0
	if (i = 20) or (i > 0 and ((c=&HA) or (c=&HD) ))
	   print "linea:";line_num;" - "; S
		while i < 20
			S(i) = " " ' pad out with spaces
			i += 1
		WRITE_LINE(line_num, S)
		line_num+=1
		if line_num=4 then line_num=0
		i = 0
		S = ""
LOOP
Re: Teensy 3.1 (3.0) with LCD 20x4
Congradulations !! A good way to start the New Year..
Hope to see more.
Gary Olzeke51
