SuperPRO parts assembly diagram
I knew I posted this on the web, and probably should put a link in the help file.
But here is the assembly diagram of the SuprePRO (rev 7)
superPRO_ASM (1).pdf
(53.58 KiB) Downloaded 2122 times
The rev 8 moved the battery components a little, and changed the JTAG to the compact 10 pin header
Re: SuperPRO parts assembly diagram
And this is the current BOM for the 8 and 8A
superPro_BOM_8a.pdf
(33.36 KiB) Downloaded 2135 times
