Attached is an Excel-97 spreadsheet that defines the pins on most of the connectors on the SuperPro,
a good place to start for any SuperPro project. A PDF version is also provided.
Correction: 8/7/20, spreadsheet shows DAC on J2-3, should be J2-2 ( P0.26)
Attached is an easy to read .GIF file of a SuperPro5 connector layout diagram (based on not so easy to read DXF file on website, will upgrade to Rev-8 when available).
SuperPro-IO Spreadsheet & Connector Layout
- Attachments
- SuperPro-IO.pdf
- (136.54 KiB) Downloaded 2394 times
- SuperPro5Layout.GIF (21.7 KiB) Viewed 32580 times
- SuperPro-IO.xls
- (32 KiB) Downloaded 2350 times
