String Functions issues
Hello BasicChip,
While investigating string functions for an LCD based Dice Roller project, I came across 2 errors in Strings.
Error 1:
this BT based 'Help'; topic [STR] example fails:: "
bst = 123 + "test123"
bst will remain empty.... --BUT it will work if the 'test123' part is FIRST!!!"
Error 2:
' the following line is copied from the BT based 'Help'; topic [String Functions]
' it fails to compile
'ast = ast + "abcd" + str(2 + 44 / 23) + str(len(cst)) + "zcxv" + chr(13) + "more stuff" + bst
Programming Flash 1114...
-ERROR C:/Users/Olzeke51/Documents/Coridium/DICEer/STRING_VARS_errs.bas: 43: Expected Operand
-ERROR C:/Users/Olzeke51/Documents/Coridium/DICEer/STRING_VARS_errs.bas: 43: expected expression
-First ERROR at line :43
I did test each of the "STR(functions)" individually and printed out their results -- see the .jpg
the attached files :: the .jpg shows Error 1 only - as I commented out the "Error 2" statement.
:: the .bas is my program with Error 2 enabled (and 'bst' is still empty
Error 2 enabled
(1.52 KiB) Downloaded 1323 times
a run with Error 1
a run with Error 1
Re: String Functions issues
Some troubleshooting results, that might shed some light on the Error 2:
original code and errors:: on a Vista Home SP1; latest (5 days ago) 'setupBasic.exe',
-ERROR  C:/Users/Olzeke51/Documents/Coridium/DICEer/STRING_VARS_errs.bas: 44: Expected Operand
-ERROR  C:/Users/Olzeke51/Documents/Coridium/DICEer/STRING_VARS_errs.bas: 44: expected expression
1) replaced the '+' with '&' - no apparent change
2) using the '&' ; I moved some text between the two str() functions
and got different error messages::
ast = ast & "abcd" & str(2 + 44 / 23) & "zcxv" & str(len(cst)) & chr(13) & "more stuff" & bst
-ERROR  C:/Users/Olzeke51/Documents/Coridium/DICEer/STRING_VARS_errs.bas: 43: expected comparison operator
3) with just one of the str() functions in line::
ast = ast & "abcd" & str(2 + 44 / 23) & "zcxv" & chr(13) & "more stuff" & bst
-ERROR  C:/Users/Olzeke51/Documents/Coridium/DICEer/STRING_VARS_errs.bas: 44: expected comparison operator
4) removed the str(2+44/33) part only [str(len)) is back in]::
ast = ast & "abcd" & "zcxv" & str(len(cst)) & chr(13) & "more stuff" & bst
5) putting the 'text' between the str() changes the error printouts !!!
AND just either str(), added this error also!!! "expected comparison operator"
HTH - GaryZ
As the doctor said, "well don't do that"
the multiple str functions in the statement are too complex to be handled in a single line. I'll have to fix that example in the help files.
So you should be able to do --
ast = "something" + str(something)
ast = ast + str(something
That's for the first error, can you boil down the next one?
in the event you would need to take an integer (say of a temperature) and add it
to the word F or C, it would take two statements::
  bst = STR(123) + "test123"
-ERROR  C:/Users/Olzeke51/Documents/Coridium/DICEer/STRING_VARS_errs.bas: 18: expected comparison operator
-ERROR  C:/Users/Olzeke51/Documents/Coridium/DICEer/STRING_VARS_errs.bas: 18: Expected Operand
-ERROR  C:/Users/Olzeke51/Documents/Coridium/DICEer/STRING_VARS_errs.bas: 18: expected expression
-First ERROR at line  :18
you are right - the examples need to be changed
And the initial bst confuses the compiler with the implied string function. So it looks like you will need to do str(first_number)
bst = 123+"something"            ' DOES NOT work
bst = "something" + 123          ' works
bst = str(123)+"something"      ' seems to not work as a single line either
I'll look into fixing that.
Error 2 might be tied into the same underlying issue of "Error 1'
it will have to be broken up into multiple statements
and the examples reworked.
end of line
did some further testing, in this order :: str(len(cst))
1) text + str(len)................ ok
2) text + 123............................. ok
3) text + 123 + str(len)................ ok
4) text + 456 + text +123 + str(len)..compiles but locks up at 'Executing"
5) text + 456 + text.................... ok
6) ext + 456 + text +123.............. compiles but locks up at 'Executing"
7) text + 456 + text + str(len)........ ok
8) text + str(len) + text + str(len)... no compiles
9) text + str(len) + text............... no compiles
10)text + str(987) + text.............. no compiles
11)text + 567 + text + str(987)....... compiles but locks up at 'Executing"
and this is the code::
#if  defined LPC1114
#include "LPC11xx.bas"
#else
  #error undefined CPU type
MAIN:
DIM ast(30) as string
DIM bst(30) as string
DIM cst(30) as string
 ast = "abcd"
  bst = "wxyz"
 cst = "123456789012345678901234567890"
 print "ast is ", ast
 print "bst is ", bst
 print "cst is ", cst
 ast = ast + "abcd" +   "zcxv" + 567 + "more stuff" + bst + str(987)
print  ast
	END
and the thot plickens
HTH - maybe you can spot a common denominator, stack issue, string nesting ???
GaryZ
