DOWNTO, Help file
DOWNTO, Help file
Hello Basicchip,
I was using the FOR/DOWNTO/NEXT routine.
Per the STEP information:
If no STEP value is specified in the FOR loop the default of 1 is used.
So I didn't put in a value for the DOWNTO /STEP value - and program doesn't run
Would recommend that on the DOWNTO help file that it be stressed to put in a (positive) value.
BTW, Your official example does have a value.
Thanks for listening,
Gary Olzeke
Re: DOWNTO, Help file
STEP is an optional keyword in FOR statements, true of all BASICs I have seen. If you have a STEP in the statement the compiler expects a value, and in your case the compiler flags it as an error
If there is no STEP keyword then 1 is assumed.
FOR i = 3 DOWNTO 0
would be the proper syntax
