RC servo testing
RC servo testing
As part of a project utilizing a lightweight RC servo, I wanted to test the limits and some 'stepping' values.
My project needed some small steps. [?More to come in a future 'Project"!?]
This utilizes Coridium's HWPWM11.bas file - as I used a Prostart board.
It also includes a 'Bit Bang' routine using a manually controlled (OUTPUT) designated pin.
Tried to 'pretty' up the code !!!!
#include "LPC11xx.bas"
'tiankongrc SG90 servo  - - 180 degrees  .5ms to 2.5ms 1.5=center
CONST Cycletime = 20000
dim ms20, ms_var, k, highTime, bigstep
'ms20 = 1
'ms_var = 500		'.5 ms for this servo - low volume
print "starting"
wait(2000)
output(9)
pwming:
'HWPWM ( channel, cycleTime, highTime )  '/microsecs
'HWPWM ( 2, 20000, highTime )
'// grz so I need to clear the old hightime and put in the new one
'//     else I get 'chatter'
highTime = 500		'.5 ms for this servo - low volume
	for k = 1 to 100
HWPWM ( 2, Cycletime, highTime ) ' chan 2 utilizes pin 9
		wait(18)
	next k
while bigstep < 9
	print "input a value of 0 to 7 "
	debugin bigstep
	hightime = bigstep * 200 +500
	T2_MR1 = 20000 - highTime + 1
	wait(12)
//  wait times could effect the chatter, had to experiment
	'wait(1000)
'	highTime += 20
'	if (ms20 mod 10) = 0
'		print ms20, highTime
'	endif
'	if highTime > 1922 then stop
'next ms20
HWPWM ( 2, Cycletime, 700 )
print "done with PWM"
stop
//		Manual testing, using 'bit banging' a port pin
zeroing:
	for k = 1 to 20
		out(9) = 1
		waitmicro(ms_var)
		out(9) = 0
		wait(18)	'just less than the max 20ms repetition rate
	next k
	stop
little_steps:
// searching for a 'little_step' value
for ms20 = 1 to 180 ' adjust upper limit to match the RC servo specification
	for k = 1 to 10		'lets the servo settle
		out(9) = 1
		waitmicro(ms_var)
		out(9) = 0
	next k
	ms_var += 11			// adjust as desired for 'little_step'
		print ms20, ms_var
next ms20
print "done"
[u]// use the Basic Tool - <STOP> button as needed[/u]
goto zeroing
end
servo-test-BB.bas
(1.84 KiB) Downloaded 1046 times
Re: RC servo testing
Hey Y'all, - - heads up
I connected some more components to my board, and started getting random failures.
One status-type LED would light up from time to time - randomly.
Chased it down to the SERVO setup - mainly the +5v line - - preliminary troubleshooting.
Not sure if the USB power cable [also had been on the serial/dongle connector]
OR if the PWM under load from the servo was/is the issue
an analog multimeter is showing a varying current of 3.5-4 ma - hmmm
[~4.9+ volts]
Y'all,
It seems that a .1uf (100nf) capacitor across the 5 & gnd at the arduino connector resolved the spurios triggers.
Only did about a 2 hour power on test.
Olzeke51
