I would use a Shift Register, and load the data serially with one data output.
Use a second data line for the shift clock and a third to load the PLL.
--- On Sun, 9/28/08, kb5pwl <donwest@magtel.com> wrote:
Subject: [ARMexpress] 8 Bits Out To Latch
To: ARMexpress@yahoogroups.com
Date: Sunday, September 28, 2008, 3:25 AM
Has anyone written any Basic code to output 8 bits to an 8-bit data
latch? I want to use an Armmite to control a PLL chip, which requires
8 parallel data lines. One method would seem to be: write the
individual bits to 8 IO or AD pins, then pulse another pin to clock
the latch.
IO expansion
Re: IO expansion
> the latch.
If you have the pins available you can use 9 IOs.
' use IO(0-7) as a bus and IO(8) as strobe
FOR I=0 to 7
IO(I) = X AND (1<<I)
NEXT I
IO(8) = 1
IO(8) = 0
Using IO() is slower as it sets the direction each time
> the latch.
FOR I=0 to 7
NEXT I
IO(8) = 1
IO(8) = 0
