PWM for LPC175x
PWM for LPC175x
>frim help line
I need some more help. The Csample.c program has
case 5:
printf("Ramp thru PWM on LED\n");
for (i=0; i<256; i++) PWM (10,255-i,200);
break;
but P0.10 is not pwm type, and the LED is P2.10. All the pwm type pins on a LPC1751 are on ports other than 0.
How can I use the PWM(pin,cycle,ms) command on a LPC1751
Re: PWM for LPC175x
We haven't written a version of HWPMW.h for the LPC175x
PWM for these NXP parts, sets up 1 timer to count to a terminal match value and then reset to 0 to count again.
Other match values will set/clear the match output. You have to program the PINSEL register to output the match output.
We did this in BASIC for those parts and you can use that as an example
HWPWM17.bas
(2.21 KiB) Downloaded 1548 times
