New (LCP812)
Re: New (LCP812)
Like anything in electronics, things change very quickly. We are now working with an ARM based WiFi module that costs only a buck or two more than the ESP8266. The advantage is that this one has enough horse power to do BASIC and serve web pages. We have some initial code working on it, and it merges a user BASIC program easily with displaying or updating BASIC variables in the web page. To program it, you use BASIC tools and combine that with some simple HTML.
So we will release the LPC812/LPC824 designs as open source.
schematics
necchaESP.pdf
(23.68 KiB) Downloaded 590 times
BASIC firmware LPC812
LPC812basic.hex
(18.45 KiB) Downloaded 592 times
BASIC firmware LPC824
LPC824basic.hex
(35.39 KiB) Downloaded 621 times
Gerbers for PCB
necchaWiFi.zip
(9.3 KiB) Downloaded 609 times
We have a few of these boards to give away, we would just like you to use them and publish what you did with them
Re: New (LCP812)
what was the outcome for this issue:?
'I took a look at the webpages.bas program and am curious about the HTTP_AD subroutine.
You refer to AD2,3,4,5 -- looking at the data sheet and user manual, the tssop20 uses
these ADC names - ADC2,3,9,10
corresponding to: name(tssop-pin) P0-14(20);p0-23(1);p0-17(2);p0-13(3)
1) are your AD4,5 mapped internally (codewise) to ADC9,10 respectively??
Thank you for releasing the hardware into the Open Source Hardware community.
I have a project in mind for an 824. I've got an esp8266-12 and a 4 opto-relay board to
use on my outdoor fish-tank. Lights, air-pump, circulating pump. [ I had trouble with my 812 HVAC
project with mechanical relays - inductive kick got into the 5v line and caused hangups]
again , Thanks Gary
Re: New (LCP812)
On the TSSOP20 package only AD2 and AD3 are available.
Our code is based on more generic NXP code which only has AD0-7, but not all those pins are available on that package.
That code source in C is published in our MakeItC download.
Re: New (LCP812)
For now this is not an active product, but I had need for a G-job that could use it so I dusted off the old the old LPC824/ESP8266 combination.
First I needed to update the firmware for the ESP8266. Wow they don't make that too easy, but I had a BASICchip board that I midified as a downloader
I didn't think that was the hard part. Figuring out which tool and firmware version of ESP8266 and how to use it was a real pain. Among the many this got me over the hump.
https://www.electronicshub.org/update-f ... -firmware/
And the update process for the 1.6.2 version seemed to handle my older parts
And I got a new version loaded on all the ESP8266s I had
Re: New (LCP812)
WooHoo, also seems like the latest update to phpBB allows multiple pictures per post again (broken 2 versions ago).
Now off to test out some code, will post it here...
Re: New (LCP812)
As we switched to the LPC824 soon after doing the LPC812, about the same price (cheap) and had twice as much memory, I am switching these posts to a new topic...
viewtopic.php?f=8&t=1296
