Ceramic resonator
Posted: Mon Feb 11, 2013 1:48 pm
>Would this resonator be a ok replacement for the one you use on your lpc2103
boards (very expensive to import to uk)
http://uk.rs-online.com/web/p/resonator/7214815/
>only difference I can see if you one had a load capacitance of 9pf and this one
has 15pf, is that ok?
I don't know the answer for sure, but most likely its OK.
But if I were doing a new design, I'd use a newer part. The LPC11xx series
parts are equivalent in performance, and don't require either an external
resonator (you can use a crystal to get a more accurate clock) or a 1.8V
regulator. And they are cheaper. If you need some more performance or a couple
UARTs, the LPC1751 is another good choice (the PROplus part)
We'll be rolling out the XB sensor and a new PRO family member when parts become
available in the TSSOP-28 package
http://www.coridium.us/ARMhelp/scr/HWPROstartPins.html
Re: Ceramic resonator
Posted: Mon Feb 11, 2013 1:50 pm
Bruce - any chance we can buy pre-programmed TSSOP or even DIP modules?
become available in the TSSOP-28 package
Posted: Mon Feb 11, 2013 1:51 pm
The part we will be using is announced here, hopefully they will be available
soon as its not new silicon, just a new package.
http://www.nxp.com/news/press-releases/ ... rollers-in\
-high-volume-tssop-and-so-packages-target-8-16-bit-applications.html
You use to be able to buy pre-programmed parts through distribution, I assume
that's still available, but its was never free unless you were doing huge
volumes.
As for DIP modules, we won't be doing any unless we see some volume. Just from
internet searches we see, it looks to us like the Parallax Stamp business is
dead, and the Arduino form factor generates 8-10x more hits.
Re: Ceramic resonator and DIP or TSSOP packages
Posted: Mon Feb 11, 2013 1:52 pm
Over the last 2+ yrs I've used some Coridium Pros, and a larger number of PICAXE
dips and have become very familiar with each, and written quite a lot of code.
IMHO - The PICAXE is a fine product for $4, BUT it is an interpreter running
typically 200-500 times slower than the PRO, and has a rather limited, somewhat
quirky BASIC. I would expect a competitively priced DIP with compiled Basic, 32
bit integers, arrays and parentheses to control order of execution, to generate
a fair bit of interest in this market. And a significant number of users make
their own boards w/SMD.
I'm not a fan of the Arduino form factor, nor am I ready to buy a commercial
license to program my own chips with ARMbasic. Maybe we could buy some dips when
available and ship them to you for programming?
Watching future announcements with interest.
DIP28 package and SO20
Posted: Mon Feb 11, 2013 1:55 pm
Since this message, NXP added a DIP28 version which is now shipping as the BASICchip
As of this writing (Jan 2013) an SO20 version of the LPC812 will be available in a couple months and we will make that a product.
In the meantime we have received some 80 of the TSSOP20 versions of the LPC812 and will be building those into breakout boards for alpha testing next month.
